Am trying to create a graph using path and facing this issue. Am seeing one view in editor and another in the actual widget. Issue is with sacaling. When I change to auto, it’s not applying in widget. But in editor it’s getting applied.
Am i missing something?
What are you trying to achieve here?
If the 3D rotation is what you mean, I think it worked as expected.
I attach a simple example of a path shape with 3D Rotation X .
In the editor
On homescreen
No…the issue is with scale…see how the path appear in editor and how it appears in widget…
As far as I know, in a Kustom preset, a path should be in square proportion instead of rectangle proportion.
CMIIW
Still it appears correctly in editor… That’s whats bugging me. Seeing something and getting something else.
Here’s what I just tried.
The top Path shape is not 3D rotated.
The bottom Path shape is 3D rotated.
