Problem with KLWP
I’ll start off with the particulars
Samsung Z Fold3,
Model: SM-F926U,
Android Version: 15
KLWP Pro: 3.79b515413
I have also downloaded, installed and upgraded to Pro 3.77b435216huawei version as well.
I did this so I could have 2 instances opened and copy from one to the other, originally I stuck with the Play Store version and only applied as wallpaper from it, but I thought, why not, so it somewhat works with either, however, some things don’t work on one version and vice versa. For instance, the LRC synced lyrics and art from [u/magicpuddin] (https://www.reddit.com/user/magicpuddin/) only works when the wallpaper is applied from the Huawei version, I can’t even recognize whether media is playing or not when applied from the Play Store version, but no $br(tasker, ###)$ data from MacroDroid works on the Huawei version, but does on the Play Store version. How can these problems be fixed? I’ve tried uninstalling, clearing everything out the Kustom folder, deleting the Kustom folder and having the app repopulate it, nothing works to get those 2 things to work at the same time.
