Another preset is imported, not the one selected.
kwgt 3.76b422110
samsung zflip5 Andriod 14
kwgt 3.76b422110
Can you check if 3.77 is already available for you and see if that makes a difference?
Thanks.
Is it a beta version?
I can,t see any update in google play.
It’s on a slow rollout so it might not be available for everyone just yet. You can, however, sideload it from the official download page
Tested version 3.77, the problem still occurs.
In addition, I tried exporting preset with English title and then importing it, it works good.
I tried it a few more times and it worked again.
At the same time, I also saw that the .kwgt file in the sdcard sometimes became 0kb; I exited the advanced editor with discard but entered the advanced editor again. I had to repeat the exit several times before I could really exit.
I gave up trying this, the widgets are working fine now anyway.
