Please Help with Kustom problem
I have a kwgt that I exported from another device. I have put the exported file into the kustom/widget directory on the new device. Then I add a widget to the screen and click on it to setup. I import the widget that I put in the kustom directory, and it looks like it did on the other device. But when I click on it, it shows a blank page and says this container is empty. Then when I look at the filed i saved in the kustom/widgets directory it is now 0 Bytes not the 162 Bytes that it was before I tried to use it.
Can anyone help me figure this out?
Thanx!!
As far as I know, when you have copied/moved the .kwgt file into the widgets folder under your Kustom installation folder, you don’t need to import from within the KWGT editor.
You can just add a new widget on your homescreen, then select it in your KWGT editor.
The IMPORT process is the process of copying a .kwgt file FROM other folder outside the widgets folder INTO the widgets folder.
Importing a kwgt file that is already in the widgets folder will fail and the file will be overridden with a zero-size file. It is like trying to copy the file to itself.
Rule of Thumb: 2 Ways to Add a New Preset to KWGT | KLWP | KLCK
File Copy (using any file manager apps)
  1. Manually copy the new preset file, from any folder to the appropriate folder:
    • KWGT: Kustom/widgets
    • KLWP: Kustom/wallpapers
    • KLCK: Kustom/lockscreens
  2. Open the Kustom editor: KWGT | KLWP | KLCK
  3. The new preset is available to choose from the Library.
Import (using the Import button in the Kustom editor)
  1. Open Open the Kustom editor: KWGT | KLWP | KLCK
  2. Tap on the [Import] button
  3. Choose the new preset file from any folder (outside the Kustom installation folder)
  4. Kustom editor will start the import process, once done the new preset will be available in the Library.
Tolong gratis kan aku mau pasang widgett
