Pause/play bitmap don’t show up in the widget even though I believe I have put the correct path of the images.
Here is the formula I use: $if(mi(state)=PLAYING,file:/storage/emulated/0/Kustom/icons/Pause.png,file:/storage/emulated/0/Kustom/icons/Play.png)$
Device is Xiaomi 13T, HyperOS 2 (Android 15). KWGT version is 3.77b435216.
A tips on using an image as a button:
- Use a global variable of Image type, to store the bitmap data in the preset.
- Point the image path to that global variable using gv() function, instead of typing the URI of the image path.
By the way, from your code snippet,
I think you should write:
file:///storage/ …
Also, make sure the image file does exist in the folder you’re using, and you write the filename correctly.
I made the images global just as you suggested and it works. Haha. Thank you very much for the help.
