I’m new to using KWGT and trying to figure out why some groups have padding options and others don’t.
When I looked at some examples, I couldn’t understand why there is padding in some cases but not others.
How does it work? I would like to have padding settings.
If you have the Group inside another Group, you’ll get the padding instead of the offset. The padding will be in reference to the border of the upper container. This will be the same for any elements.
