It says invalid shortcut when I try to add outlook calendar shortcut.
It works in Total launcher with outlook calendar shortcut why I’m guessing the problem is in kustom, but I don’t know. I’m using a samsung galaxy s22 ultra. It has been like this for quite a while.
- Install app shortcut maker
- In kustom use touch - shortcut
- Find shortcut maker’s “select shortcut”
- Shortcut maker app opens, select “inner links” - outlook show calendar.
- Uninstall shortcut maker - no need for it after that.
Thanks, it worked well.
