This may have been brought up already but I cannot get any weather data on my watch face. I figure its a problem with the watch blocking it as it updates just fine in the editor. I’ve tried all of the komponets and whatnot, and all of the weather providers.
It gives me something when I fix the location to a specific place (instead of using Auto GPS) but it still doesn’t update correctly for me. Really hoping a fix comes soon, since I’m really looking forward to getting to use the watchface I’m cooking up with this.
It seems to load for me now, but it doesn’t refresh regularly…? I have a watchface designed which relies on forecast data, which seems to only load when the watchface first loads. To get it to update I always have to change watchfaces and then change back, at which point the data updates.
Even with the latest version? Whenever the phone will get weather data it should update properly, i will check if there is anything i left out (and sorry for the delay)
No worries, and yes, this was with the fully latest version (Play store) on both phone and watch. Unfortunately I ended up having to switch back to my prior watchface as the stale weather data + disappearing ambient display were making it impractical for daily use…I look forward to trying it again though!
