Nintendo Music not detected by KWGT music player
Nintendo Music isn’t detected in the music player selection popup, and also isn’t detected in the automatic setting. It creates a media session detected by my phone, so not sure why it doesn’t work.
This is usually due to a compliance issue. KWGT auto-detects music players that are compliant with Android music player standards. If your app is not listed, it is most likely not compliant. I suggest you talk to the app developer first.
On top of what Ace correctly suggested I can hardcode players that are not detected, is package “com.nintendo.znba”? If so i will add this in 3.78, also from 3.78 i will be able to update the list without releasing a new version.
Package name does indeed seem to be “com.nintendo.znba”.
Then just wait for 3.78 beta (in a few weeks hopefully)
