Newbie needs help
(I’m new to this application so I might have posted stupid questions)
I’ve used morphing text on the title, artist and current track position/duration but there is a delay on the song change or not even load (the current song is c#nt by issbrokie)
Also I tested with an alternate music player (mixtube)
And it doesn’t respond, do you know the problem?
does changing song while in kustom editor preview changes immideatly or it also takes delay in the preview? also is it for klck or klwp?
There is some update “lag” in KWGT as it only updates at certain intervals (so it can’t detect immediate changes).
Check in Settings > Advanced Options > Update Mode what your settings are and change them to what you want.
