New user pro key issue
Ive downloaded kwgt and kwgt pro from playstore. Kwgt opens fine but when i click on the pro download i simply get the text kwgt pop up over my screen with no option other than backing out. Downloaded a third party app (feast for kwgt) and upon ope ing that app i get a page saying im missing the kwgt apps.
Searched reddit and help links and cant seem to find anything. Im sure when someone points me in the right direction ill look pretty stupid but any help would be appreciated.
The KWGT Pro Key app is not really meant to be open separately. It’s just there to upgrade the main KWGT editor to the Pro version. To check, go to the KWGT editor’s app settings and check if it says Free or Pro at the top.
Thanks! I did check that and saw it said pro at the top. But what threw me off was when i downloaded a third party app with kwgt packs in it. Upon opening those it said i was missing kwgt and pro.
It would make sense if those third party apps were a download file that you would import into kwgt but that isnt the case, i must be missing something.
Im having the same exact issue. Except now it goes to the app info when i click on it. I also went to the main app to see if it had pro, it has pro at the the top be it looks as if its not activated. Its not illuminated.
If it says Pro at the top, Pro is installed/activated, it’s not “illuminated”.
If Pro is not active, it won’t say Pro at all.
The third party apps with widgets are made by third parties, so they react as their creator wants them to react. You can see them in KWGT under the Installed packs section.
Hi everyone, I’ve bought the pro version, have the screenshot of the payment but the app still the same! Asking me for buy it again… what I’m missing? Thanks a lot
If your license is in-app, you don’t need the separate Pro Key app. However, some widgets may check for the Pro Key app to confirm your pro status. To bypass this, load the widget directly in KWGT by going to Load Preset > Installed Packs > selecting the desired widget pack.
