New Icon Feature Issue
Okay so I’m not entirely sure if this is a Kustom issue or if I’m just missing something, but I’ll try n explain what happens and hopefully someone can tell me what I am not grasping.
I’m currently on the lastest release of Kustom. I wanted to try the recent integration with Iconify. Whenever I choose to add an icon everything works normally. It will bring up all the Iconify icon packs and also my own from storage. I can sort and filter and all those options work. But my problem happens after I pick the pack, then try to pick a specific icon from the pack. Normally when you do that it will display all icons from the pack you chose and you look through and find what you want. When I do it now, it just shows me a search bar and a blank page, but no icons to pick from.
After I pick which pack I want and try to change the icon, do I just need to wait a little longer and allow it to load the icons? Am I being impatient?
I also realize this is a newer feature and perhaps has a few bugs so I may just need to wait for a couple releases to see this feature fully functional.
If anyone has any input or advice I’d be appreciative
Hi @allday5850 ,
Which Kustom products do you mean? Is it KWGT, KLWP, or KLCK?
