My klwp wallpaper becomes blank. My phone is Iqoo 7 legend
Check if this is a compatibility issue. Go to KLWP’s app settings >> Advanced options >> Turn on “Disable Parallel Rendering”.
I have this issue too. I have tried disabling the parallel rendering but it doesn’t help. The image I use as background shows in KLWP editor but shows blank on homescreen.
It doesn’t do this for all background images, just some (newer taken / added) images.
Strangely, if I force a rotate of the screen the image appears! …and disappears again when back in portrait.
Running stock on Samsung Z-Flip 4 (latest update OneUI 6.1)
Can you check and make sure to remove KLWP from your device’s battery optimization?
There are no battery restrictions for klwp and this problem im seeing very recently, the wallpaper which im using is not a new one its been a long time.
