halo, I’d like to know why the music player is glitching (at least in the widget) because when I apply the formulas, the animation plays, but when I save it, the checkmarks appear and the spacebar doesn’t advance or skips minutes. For example: (1:13 skips to 1:20 while the song is playing) Is there a solution for this? Thanks ![]()
By default, Kustom updates music info every 5 seconds, which causes that stuttering or skipping effect.
If you want the progress bar to update smoothly every second on your home screen, do this:Open Kustom Settings - General Settings.Go to Advanced Options - Update Mode.Set Update Mode to Fast. Keep in mind: this mode uses more battery.
Also make sure to set Kustom to Unrestricted in your phone’s battery optimization settings.
