Hi, I’ve tried to build a music widget but music info just don’t appear, neither the cover nor the title or the author. It worked till few weeks ago but now it’s like this.
I’m on a Samsung Galaxy Z fold 7 with OneUI 8.5
You need to make sure Kustom has Notification Access enabled. Here is what you need to do:
Go to your phone Settings → Apps.
Tap the three dots in the top right corner and select Special access (or search for “Notification access” in the settings search bar).
Find KWGT/KLWP in the list and toggle the switch ON.
Great, it worked! Thank you very much, appreciated it.
