Music cover not showing
We need some more info to help you out…
Phone, OS, version of KLWP, what is the code you’re trying to use, etc.
Samsung s23 ultra android 6.1 nova launcher and the code it for klwp image for music $mi(cover))$
Hi,
Aside from possible typos in using the function, there might be possible that the track does not have its cover/album art.
The Kustom app pulls the cover photo from the notification panel so first, make sure that the app has notification access enabled. Also, make sure that the music player you’re using displays the cover photo in the notification panel.
Didn’t know that, thanks for the info!
