When making a gradient, I was adding more colors with a global variable to make the gradient more granular. However, it revealed that apparently Kustom doesn’t like multiple of the same vars up to some point
I can’t seem to reproduce this issue on my end. Can you make sure that you have the latest version of the Kustom app installed? If it’s not available in the Play Store for you, you can sideload it from the link below.
check the formula again, there’s double comma in the second line.
I think you are referring to the output and not the formula.
