Moon phase formula
Hello guys I’ve created a font with 32 moon phase characters and I was going to create a formula to show the correct illumination level. However.. it proved to be a little too complicated for me. I kind of know what the formula should look like but putting it together is really something else.
I was thinking a combination of moon phase code $ai(mphasec)$ and illumination percentage $ai(mill)$..?
Below is a link to the ttf file and a simple character reference widget in case some kind person has the time and feels like helping me out with this! :folded_hands:t2:
Hi. You can map all 32 characters of your font into a single string and use the moon phase index ($ai(mage)$) to slice out the exact letter instantly. Try this formula for test in your text element:
Index: $ai(mage)$ | Phase: $tc(cut, “ABCDEFGHIJKLMNOPQRSTUVWXYZabcdef”, ai(mage), 1)$
If everything matches and works correctly, just create a Text Global variable (let’s call it moon), paste your full 32-character alphabet string into it, and use this formula in your text element $tc(cut, gv(moon), ai(mage), 1)$
All right thanks I’ll give it a shot!
It seems to be working! Thanks!
Edit. It’s pretty awesome actually :slightly_smiling_face:
