Missing Requirements fix now pop-up
Graphical glitch, or this might just be the OS I’m using, GrapheneOS, being annoying, anyway, I get this pop up every time I open KLWP, they are not missing, I have used the Kustom booster, and I have no issues with the functions.
Hi @Cindanela ,
Did you try the FIX NOW button successfully?
I have been experiencing the same issue on my phone (MIUI v14.0.1; Android 12). I have Kustom Booster installed (replacing the Kustom Unread add-on), however the issue is still around without any solution.
Let’s hope the developer could investigate and troubleshoot this issue soon.
@frank :
Could you please help us with this issue?
:folded_hands::smiling_face:
I believe KBooster still requires Health Connect permission to access and provide health-related data, so please make sure that permission is enabled.
Hi @Ace ,
Do you have any ideas on the cause of these errors and probably any solutions to them?
I have granted all permissions to Kustom Booster but I still got those errors.
Just install a version older than 3.82 and all the problems should disappear. It’s only a temporary workaround, but I haven’t updated for a very long time and everything has been working fine.
Hi @MaxP ,
Thank you for your tips. So, I guess that the issue is in the v3.82.
KBooster is only required for versions newer than 3.81, because the Google…so you won’t need to install it. Just grant the usual permissions, like we’ve always done.
