When I set primary location to Auto (GPS), widget does not show location, its just blank. I have High Accuracy enabled both in Android and the app settings. Location and sensor permissions are granted. Changing weather provider does not work. Force update gives
Location not detected correctly, please enable gps/network positioning.
I also tried reinstalling, clearing cache and data.
I've had to disable "Google Location Accuracy" and WiFi, Bluetooth scanning so the phone is in GPS only mode to get proper location on my phone, when GPS is the only reliable source of location data. Otherwise my phone ignores GPS even if network location is grossly inaccurate and reports locations miles away from me.
Then I either use high accuracy mode in KWGT which keeps GPS on all the time, or alternatively I use another app... GPS Logger for Android set to turn GPS on at a set interval, like every 10 minutes (or any other time interval).
If your widget shows a blank location when set to Auto (GPS) despite having High Accuracy enabled, permissions granted, and even after reinstalling and clearing data, the issue likely lies with how the app accesses GPS data. The error message suggests that, despite settings, the device isn’t providing accurate location data to the app. Try disabling and re-enabling location services, ensure no battery optimization is affecting the app, and test GPS with other apps to confirm it’s working system-wide. If the problem persists, contact the app developer for a fix.
