KWGT WiFi name appear then disappear
On my new Samsung S25+ with OneUI 7 Android 15, the Wifi name will appear for 2 to 3 seconds and then disappear. On my older Samsung S23U with OneUI 6 Android 14 no such issue. Both are using the same version 3.78b510818, wonder was it OneUI 7 Android 15 causing this issue.
Can you make sure that Location is enabled in your S25+?
Yes, Location is enabled. This command $nc(ssid)$ works fine on my old phone running Android 14 when the Connected WiFi name stay on. Only my new phone happen the WiFi name will appear for a split seconds and then disappear.
i see alot of issues after UI 7 came out i can even use my home screen after unlocking with Kustom Lock
My case everything worked fine Date, Time, Day, Battery % status with Kustom Widget except the mentioned issue WiFi name will appear and then disappear. I also think is UI 7 Android 15 issue since already given all necessary permissions, Location and disable Battery Optimization. Hope there will be a new release by the team soon.
Aright, resolve my this issue by uninstall reinstall Kustom Widget and redo all setup. WiFi name appear and remain and won’t disappear.
