Hi! I’m working on a clock that I’ve recreated from an old rainmeter skin and I’d like to add CRT scanlines and also chromatic aberration over it (CRT scanlines at least). Anyone else seeing Overlap Group redraw/ghosting issues after deployment?
In the editor everything looks fine. But once deployed as KWGT widget, dynamic weather/location/time updates stack/ ghost old renders instead of clearing them (see the time, day and location on the clock on picrel plz). Same items at root update fine; the issue starts when they’re inside an Overlap Group w the crt or any fx. Tested w and I see this happening in smart and hyperion launchers. Started noticing it while testing 3.82 shader FX.
Thanks for the response! v3.81 does not have the new FX features like scanlines, it’s a new addition in 3.82. I’m hoping though this isn’t a bug, because I’d really like to fix this in the app tbh.
I’m not using 3.82, but I think the issue is related to that version and the new features. I believe you just need to wait for an update from the developer.
