buddy, that’s global variable enabled. in order to use custom font you want to use select the checkmark button on right then after that you should see the globe icon at very top right corner click on that and after that you should be able to use your desired font in font picker. or you could go to your globals tab in root of widget where you could pick font there.
here is selection example image where I highlighted
