Semi circle progress bar would be a great addition for when you don’t want a full circle bar
You can use an Arc shape to do this. Check the tutorial from the link below.
I appreciate the help, I was able to do the bar and add colors but the color formula is not working, could it be because the formula does not accept the condition if(and( , also the sweep gradient it is not moving with the battery life, this is the formula I used for it
$bi(level)$ , actually it’s not moving with any formula, do you have any idea of that the issue may be
On Tue, Oct 10,
Make sure to use data from your watch complications when you do this. You can use the information from the link below as a guide on how to pull data from complications you can use in your progress.
