Kwch not updating weather even after force
I have current temperature showing on my watchface, but it doesn’t seem to update correctly.
I have also set up so I can force update weather by touch but it doesn’t seem to work if I’m not connected to wifi.
I’ve read in previous threads that it would be added (fetching over Bluetooth) in version 3.75 but I can’t get it to work. I’m worried I’m doing something wrong or misunderstood something. Should it be working without wifi?
I’m using the latest build 3.75 from play store, also updated on the watch.
Did you found a solution?
Unfortunately no.
The weather update system is a little hit and miss in my opinion. Sometimes it works great but sometimes it won’t work without a full reboot of both watch and phone. It has been working better with later versions but it’s still there at times.
Ich habe seit Jahren das gleiche Problem mit dem Wetterupdate . Es funktioniert nur mit wlan, auch per Berührung. Allerdings frisst das sehr viel Akku. Die Uhr hält keinen Tag. Ich würde mir auch eine Aktualisierung per bluetooth wünschen.
