Kwch Complications Bug
Kwch (version 0.01b421511) on the watch has problems selecting and saving the data slot for complications in the customize settings menu. It seems no matter what data slot, the info that is selected to show is not saved when selected and defaults to a calendar event. Please let me know if further information is needed.
This seems to be working for me just fine on this version. May I know how you’re testing this?
Interesting. I’m just trying to select ‘feels like weather’ to slot 1 (or any slot) and it keeps opening the same thing no matter what. I’ll try a fresh install and see if that fixes it and report back.
Sooo I did not do a fresh install yet.
I went and set every complication data slot one through eight to none. It appeared to save because after I selected them all I double checked the first data slot and the scroll bar was still positioned at the top whereas if it were another option it would be scrolled showing it’s text. I then tried applying this by selecting to apply the watch face with no success and also just backing out of all settings until back on the watch face home screen with same results, no success. They all default to ‘day of the week’ except one to ‘battery’.
Oddly enough, variables decided to start passing phone to watch out of nowhere so hey, I’ll take whatever I can get lol. I hardly ever use the complications but have been pulling my hair out (I’m bald) trying to pass variables lol.
I’m an idiot and didn’t reply to your comment and just replied to the thread but I just did a fresh install on the watch and still got the same results.
Got it. May I have the formula you use to display the complications?
I’m not displaying complication data, I’m just trying to set the on tap data, I’m sorry if I was using incorrect terms. I can update post if so, so it won’t be confusing for future reads.
I have the same issue. Had to select all complications through the Samsung wear app manually.
Whoa, glad to know I’m not alone and you’ve found a workaround.
Is this problem only for Samsung watches? Thanks for the wearable app workaround discovery. but devs need to resolve this, I spent too much time figuring out If I suddenly lost my ability to create Kustom Komponents or something. I doubted myself a bit there
