Kustom Pro Transfer
I got a new phone and want to transfer my Pro account to the new phone but I can’t find a way to do it. I already paid $6.99 for the app on the older phones twice and don’t want to pay again. Can someone help ..
Since the Pro license is tied to your Google Account, not your hardware, here is how you can restore it on your new phone:
Check your Google Account:
Make sure you are signed into the Google Play Store on your new phone with the exact same email address you used for the original purchase.
If you bought the “Pro Key” (Separate App):
Just go to the Play Store, find “KWGT Kustom Widget Pro Key” (or KLWP), and it should show as “Install” or “Owned” instead of a price. Install it alongside the main app.
If you bought “In-App Purchase” (Inside the free app):
Open the Kustom app on your new phone.
Tap the side menu (three lines) and look for “Restore Purchase” or simply click on “Get Pro”.
The Play Store window will pop up. If you are on the correct account, it should recognize the previous purchase and activate Pro automatically without charging you again.
If it still shows a price, it’s often a Google Play cache issue.
Close the Play Store.
Go to Phone Settings > Apps > Google Play Store > Clear Cache.
Restart the Play Store and try again.
If nothing works, you can contact at [email protected].
