Kustom action "Open Notification" does not work with launcher KISS
Hello,
I am using KLWP in combination with the launcher KISS.
I have set up a notification "area/widget" listing all current notifications in my KLWP wallpaper. Clicking the main notification has the action "Open Notification" and the icon has "Dismiss Notification". "Send touch events to wallpaper" in KISS is active.
Everything works well (dismiss notification, open apps, ...) except the "Open Notification" action. Is this something related to KLWP or to the launcher?
Could you please help me pointing this issue into the correct direction?
GitHub KISS launcher: https://github.com/Neamar/KISS
I'm not in the last version of Klwp (mine is 3.38) but in Kwgt it's working well the open notification and in my Klwp too.
If you had a touch and selected the proper index notification in Klwp and it not open the notification, I think that the problem is in your launcher.
Thanks for your answer. It seems to depend on the launcher ... when I use Nova the "Open Notification" works fine.
I was wondering if there is s.th. within the KLWP code which has to "register" the launcher or s.th... (since dismiss works in KISS)
I use Smart Launcher 6. Notifications used to work just fine, they showed and were clickable. But since 2/3 months, are not clickable anymore. Please help!
I’m experiencing the same with Nova Launcher.
Switched from a OnePlus Nord with Android 11 to a OnePlus Nord 4 with Android 14 and now 15. I’m using the same KLWP wallpaper on both phones but clicking on notifications does not work for most apps on Android 14/15.
Strange enough it does work for notifications from the Home Assistant app. Just not for pretty much else like Gmail, Whatsapp, Slack, etc.
I can tell the touch action is being registered on these notifications as there is a vibration but it just doesnt open the corresponding app unless it’s a Home Assistant notification.
I’m also expiriencing the same problems. Click on notification to trigger Open notification gives a vibrating feedback but nothing happens. The Dismiss notification action works. I’m also using Nova launcher
I’m really annoyed by this, especially since it works for my Home Assistant notifications. I’d really like to dig into this to see if there is a pattern that can help identify the cause of this issue.
@Tbyte @Jure_Simon , arent any of your notification touch actions working or do you also have apps that do work. And what is your environment?
I’m using:
  • Phone: OnePlus Nord 4
  • OS: Android 15
  • Software:: KLWP Pro (latest)
  • Notifications: Home Assistant works, everything else like Gmail, Whatsapp, Slack, etc. does not.
Perhaps with more info we can see a pattern.
This is fixed in 3.79, beta is now available at Downloads | Kustom HQ and in beta channel, release will be out next week.
Awesome, installed the beta and this issue is indeed fixed. You have made my day!
Good news after lomg time waiting! I can’t install beta, so I hope 3.79 will release soon.
