Meu Flows downloads JSON estou com o seguinte problema:
Could you please show what’s inside your gv(json) global? Also, try to output it as raw text using $wg(gv(json), raw)$ to see if Kustom can actually access the file.
Hi @Adacir_Pereira ,
IMO the problem was caused by either incorrect file path, no file found, or file access permission by the OS.
Send an email to [email protected] so they can track this down for you. Usually an easy and quick fix.
