KLWP preset have some like scratches when applied as wallpaper
I have making some preset for klwp, when i applied as wallpaper there some scratches in top and bottom screen like this :
Its not hapen in regular wallpaper, i have search on google but not found problem like this, is anyone can help me about this?
Device : Redmi Note 8 Pro
Android : 11
KLWP ver : 3.77b432414
Go to KLWP’s app settings >> Advanced options >> Turn on “Disable parallel rendering”.
Thanks for advice, have enable “disable pararel render” And still have the same issue
Can you check if MIUI Optimization is enabled in your device under developer options? Also, is this affecting every theme that you apply or just this one?
Thanks for advice, i have turn off miui optimization and try new preset with only background color, and still have same issue
Update : i have try on other color like white, pure black and other color, this issue has appear only spesific color (gray & dark gray), any i have no idea what happen now
Last update :
I have re-install anything (klwp & nova launcher), i dont know what happen and now its solved.
Great! Thank you for sharing this information.
