Hi all,
Wondering if anyone has any ideas about this. Coming from OnePlus9Pro which was also running ColorOS 15, where KLWP worked absolutely fine.
On the new Oppo, if I try to set it as LWP, I get nothing showing up. I’ve tried downloading a different LWP to check, and that displayed fine (double helix).
I had to do a bit of a work around to get Nova Launcher running on this phone, so I’m thinking they have locked it down a bit more than I am accustomed to. I have checked all the usual permissions. It just won’t display.
I was able to install and use KWGT, and it works fine. but I would prefer to use KLWP if at all possible.
Does anyone have any experience of this and a possible solution? Apologies for not being more specific about what I have tried so far, but if it’s permission based I’ve probably done it! Battery usage as well.
