KLWP not sending colors
Whenever the background image in klwp changes, it should ideally broadcast the colors so that the system and launcher update the material you colors. This happens when you open the klwp app and click on save. However when the image changes in the background (such as if background is set to mi(cover)), it does not.
Wallpapers like muzei, when we change the background image (through autotools), the material you colors gets updated.
Can we add something in klwp to fix this?
Is there any chance this can be fixed or worked? I have the exact same issue. I use KLWP to blur my wallpaper in Niagara. But, material you colors the messed up.
