KLWP not displaying anything
My KLWP suddenly stopped working the other day. I can hit save and see everything fine but after a minute or two the whole wallpaper goes blank, showing only the solid background color. I can still interact with buttons even though they cannot be seen.
I am on a Samsung S21
KLWP version 3.80b
Start with the classic parallel rendering. Go to KLWP’s app settings >> Advanced options >> Turn on “Disable Parallel Rendering”.
I have same issue and I tried the parallel rendering and thought it fixed it but screen still went blank. Reverted back to last update
I have uploaded a new beta which should fix the issue, please download it from Downloads | Kustom HQ if you still have problems i will need the preset you are using to see if i can reproduce anything
This does seem to have fixed it. Thank you!
I’m having this same issue, though I don’t see a beta version to download at the link.
Version 3.80 is technically in beta. This is slowly being rolled out. If it’s not available for you in the Play Store yet, sideload it from Downloads | Kustom HQ.
I noticed KLWP updated today and that’s when the issue started, I am using version 3.80b.
Also having these issues on the latest google play update. Parallel rendering mode lets my screen appear but it stays frozen. Seems like the actual loading time increased significantly, as before it’d freeze for a few seconds before working
I am halting production rollout, i have changed quite a few things in the GL backend on this release, would you mind sharing your android version and ideally the preset having issues so i can test it?
I noticed my full version number was 3.80b519207 and the downloads page showed 3.80b519513 as the latest version (Google Play showed the app as up to date), so I downloaded 519513 and that appears to have fixed it.
Android 13
It won’t let me upload because I’m a new user.
Android 11 here. I got my preset from here: File folder on MEGA
Edit: did the same as above, seems to work now and better than before
Guys that was fast! Yeah i just updated KLWP disabling VB (virtual buffer) optimization as it was probably the issue. Thanks for confirming!!!
