KLWP keeps freezing and wont change pages on home screen
So ive got a Fold 6, and im using a wallpaper set up made for folds. I set a wallpaper, it works for maybe a minute and then just freezes. I can still use buttons but it just locks up and bo matter what i do nothing fixes it. Ive even went so far as to reset my phone, and still nothing… on a side note, whats the resolution limit for images? Ive tried to set some as the background on themes and its just white unless i crop it all to hell
Check if this has anything to do with parallel rendering. Go to KLWP’s app settings > > Advanced options >> Turn on “Disable parallel rendering”.
Thats one of the first things i did, even re-enabled it jist to see and of course that made it worse
Currently I am working on new klwp theme and I have same problem with freezing. When I turn on “Disable parallel rendering”. I have problem with black screen on Nova Launcher. And again and again I need to go on klwp app and go to save again and again the theme. When I Turn off “Disable parallel rendering” the problem with freezing the klwp theme continue from time to time.
