Klwp editor repeatedly crashes
After opening the KLWP editor (I’m using a OnePlus 12 Pro with Android OxygenOS V. 16.0.5), and waiting for around 2 to 4 minutes or so for the custom-made preset that’s usually applied to finally load. Now, although I don’t really believe that the reason for it taking this long to load has anything to do with the issue at hand (which can most likely be attributed to the not insignificant number of images that haven’t necessarily been optimized for a quicker loading time), I figured that I’d throw that in as well in order to offer as much information as possible. Anyhow, once that initial part is over, and just as soon as everything loads, the preset comes up visually, along with that notification bar that’s part of the KLWP editor showing up at the bottom, that’s when the whole, horrible saga begins. I get that stupid, standard looking dialogue box that’s system-generated with only those two options to choose from, either force closing the app or waiting for more time, I can only keep hitting the wait button over and over until I’ve finally finished whatever edits I was making to the preset. But, regardless of how many times I hit that f*ucking wait button, that little gray box always comes back up after about 5 to 10 seconds later. Then, that annoying, repetitive “dance” that I’ve been forced into participating in simply goes on for what I can only imagine is no less than an amount of time approaching infinity. And seeing as I’m just physically incapable of continuing for that length of time, ultimately I must acquiesce to those unfair demands put forth by the system, and finally hit that dreaded, terrifying little button labeled: “Close App”.
Help? Please?
I can add whatever additional information that may be required if you request it.
Try creating an absolutely blank, empty preset. Does the issue persist?
