Hi all, I have been using a KLWP theme for a while. I use tasker to download an image and setup the path of the image as a variable called wally. The path appears correctly in klwp but the background image is not applied. It used to work before but stopped working since last 2 weeks. Please advice. Screenshot with the setting is attached, and as you can see the image is not being applied in the preview. The image does exist in the path indicated.
storage permission issue i.g.
use global bitmap or flows
Resolved. Thanks much!!!
