I have a Google Pixel 7(doesn’t have any way to use an SD card), and when I try to use the AOSP version of KLWP, whenever I try to import a file, it is asking me for this permission, which I can’t give the app, as my phone can’t use that permission.
The AOSP version is Google service free and you’re running it on a Google phone. That may create some issues. Does the regular Play Store version work fine for you?
I figured it how to import it.
I just had to put the klwp file directly into the folder directly.
