KLWP 3.78 - Broadcat/Flow stop working
Hello,
I use broadcast from Tasker and Niagara launcher to execute flows.
$br(tasker,animTasker)$
$br(niagara-launcher, screen)$
Everything works well and smooth with the 3.77 but it stops working with the 3.78. (after few minutes)
If I run the flow from a button, it works, so I imagine a problem with the broadcast.
I’m on S24 Ultra Android 15.
Thanks.
Up up
Nobody to confirm, test it ?
:thinking:
Im looking into this, there are indeed a few reports on flow issues, sorry
Thanks, I’m waiting with 3.77 for now.
No problem, I just hope the problem isn’t samsung/device related and stay blocked with this version.
This is fixed in v3.79, new version is bring approved in beta channel can be manually downloaded at Downloads | Kustom HQ
Sorry, come back on 3.77 again.
Try 3.79 and that seem solved some issues but after save my wallpaper (change only a color), it’s not flawless and fluid as 3.77.
Can you share with me at [email protected] your preset so i can profile it?
For now, everything is working like a charm with 3.79 playstore.
:+1::+1::+1:
Great, thanks for confirming a fix, will mark as resolved
