KLCK NOT WORKING SHOWS THE STOCK LS SOMETIMES. I HAVE TO PRESS LOCK/ UNLOCK BUTTON TO FINALLY SHOW KUSTOM LS. THIS IS FRUSTRATING PLEASE FIX!! Overall thanks for the awesome apps!!
Any fix for this? I have same issues with Galaxy S10
Same here! Downloaded yesterday and not working, something after a reboot it'll show up for half a second then just stops working again.
I finally stopped using KLCK Going to wait and see if issue gets fixed. I'll stick with goodlock for now. 🙁
I found a fix. It seems that on my galaxy s10 if you remove all security and set KLCK. And then set security it works with no issues.
Same here. Any fix for this issue, please?
I've followed tutorials on YouTube and read everything I can find about KLCK, as well as set up entire Lock Screens and can NEVER GET it to appear on my Lock Screen, not even once.... what am I missing here?
Is this another Samsung issue?
How do I go about disabling the security on my Samsung Note 10 in order to try this?
I am now using a note20 ultra. I have been able use this with no issues on android 11 UI3.0.
to set it you need to open KLCK and have the lockscreen in editor mode. Press the hamburger in the top left and toggle lockscreen on. Tap the screen to close menu and click the save button.
It should work now. I did have to set it to hide notifications on lockscreen so the screen doesn't wake up for every notification
Hope that helps
