KLCK 3.82 Clear Filter and Gradient Rendering Issue
I’m on an S23U running One UI 8. I just updated to KLCK 3.82, which has completely broken the Clear filter as well as how stacked gradients are rendered.
After some testing, the Clear filter works for the first few paint passes after a fresh save, but then quickly stops working. I haven’t dug into the gradients much yet, but that’s a whole different issue.
I’m not sure how to attach images here, but I created a Reddit post with before and after images: https://www.reddit.com/r/kustom/s/8NJT9xvoUm
Before the update the gradients were overlaid and stacking nicely, and the Clear filter was punching through on the border and in the center of the words. Now it’s completely fallen apart. There may be other issues that 3.82 introduced that I haven’t noticed yet, but the two biggest ones that I’ve noticed are the filters and stacked gradient rendering.
I’d be more than happy to share the .klck file and give more specific details if it would help fix the issue.
This is a confirmed issue with the new 3.82 rendering engine.
Your best options right now are to wait for an official fix or manually downgrade to the previous stable version.
(Make sure to backup your presets before uninstalling 3.82!)
