In the KLCK app ive run into a problem. Whenever i apply a KLCK and turn the switch to “Lockscreen on”, it’ll apply the KLCK fine, although the problem im dealing with now is… the status bar and notch placement is moved down from the current place. Does anybody know a fix? Is it something I’m doing wrong or haven’t set properly.
Please DM me if there is a fix, thanks!
