I stored a JSON file containing a lot of data.
For example, I have a global variable SOURCE
that contains the JSON path. There is also a second global variable TITLE
that fetches the title from the source using the wget
JSON formula.
It works fine. However, the problem arises when the data in the JSON file is changed—Kustom does not immediately update the data in the global variable.
I tried various workarounds, but none of them worked. For instance, I used the formula $if(df(ss)=K,W)$
after the main formula to update the global every second. I also tried using the RAW formula and then reading it as JSON (this failed miserably and did not work). Additionally, using the LV formula didn’t work either. I attempted to update the path every minute via flow, but this was also unsuccessful. I’ve tried every possible method I know, but all have failed.
I need your help to update the global variables as soon as the JSON file gets updated.
