Issues to apply Cyberpunk KWGT widgets
Hi everyone!
I’m facing a issue to apply the cyberpunk KWGT widgets.
I’ve bought the package, bit to apply or asks to use KWGT Pro.
If I close the windows allert only shows the “Kustom logo :sob::sob::sob::sob:
There is anyone else has been faced this issue before, or there is a way to apply this widgets?
Follow the screenshots:
Just load the widget from within KWGT. Just add an empty Kustom widget >> Load preset >> Explore tab >> Installed packs.
it’s meant your widget pack need kwgt pro to use them.
you should read the description on app store.
