I have two curved objects that move by using a formula. When I click a button at rhe top, a flow occurs, updating the color value of some things(also using a formula) and moving the curved objects. In the editor, both things happen simultaneously. On the home screen, the colors update as I click the button, but the curved objects move a bit after that. Does anybody know how to fix?
Try to test it without Flows first. Put color change and animation on a simple Global Switch. If you use ReactOn → Formula for movement, change it to ReactOn → Global Switch. Formula animations often lag on the homescreen compared to the editor. If that doesn’t help, it might be a launcher or battery‑saver issue.
Global switch animations for the movement make it work! I used to do a position that uses a formula but now I just did an animation that uses scroll, and multiplies the formula by 0.14167777 for some reason.
