Hello. A problem. I upgraded to Pro and when I did it gave me the option to upgrade internally or to get the upgrade as a separate app. I chose the former as I didn’t see the point in getting more clutter.
But this caused a problem. I bought a theme that needs that external pro key. So what now? Can you give me the pro key? It technically doesn’t make a difference since I paid already. Or can you roll back my upgrade and refund it so I buy the external key?
In-app purchase do not require the separate pro key app. Some presets were designed to look for the separate pro key app. If you have one, you can load them directly from within KLWP. Just go to the Load Preset screen >> Explore tab >> Installed packs.
