Sofia
December 25, 2023, 3:06pm
1
I’m trying to open a preset from a custom app using an intent (i only added the intent and the file) but when i try to make the import, KLWP its unable to find the file.
Is there any dependencies or plugins to add in graddle or a provider on manifest? If you can send an example app i would be very grateful.
Ace
December 27, 2023, 7:02pm
2
Check the article below and see if this helps.
Load a preset in the editor from external app # Starting from 3.16 Kustom allows external apps to directly open a preset into the editor, this is very useful for Dashboards or preset packs in generals. So, how to do that?
Build a Kustom Uri # You...
Sofia
December 27, 2023, 11:23pm
3
I did that step by step, but it shows the bug I reported, I’m not sure if I need to add some dependency in gradle.build or a “provider” in manifest.
