Example: you have two centered squares. A is 200x200 and B is 250x250. If A uses clip, the squares will be identical. I want ‘inverse clip’ to make only 50x50 at B’s edge visible.
I tried using an svg path but couldn’t get it to work, might experiment some more but this feature would make it a lot easier anyway ![]()
