Inner Outline/Stroke
In kustom, when you use paint type stroke it grows from the center. That means it will change the actual shape slightly. This makes it difficult when a shape with outline is put into stack group multiple times, as the small size difference get bigger. This unpreciseness makes it hard to align things. It would be nice if theres a option for inside stroke like in figma where the stroke just grows to the center of a shape, leaving the shapes size intact.
