How do I make text scroll from one side of the screen to the other and repeat like a carousel effect? I’ve tried to use animations to create this effect but the text continues to return to the center. Please help. Thank you!
Check the discussion from this Reddit post and see if this will work for you.
https://www.reddit.com/r/kustom/comments/61wd3o/is_it_possible_to_have_this_text_scroll_to_show/
