https://i.imgur.com/xvNbUWk.gif
This gif should show what I’m trying to describe. It’s a little annoying and slows down my process.
I can’t seem to reproduce your issue. Does it matter what you type in the text field?
No, this happens when I type anything at all.
Can’t seem to reproduce this. Can you try the latest beta and see if that helps?
I’m already on 3.75b
There are a couple of 3.75beta. Make sure it’s the latest one. If it is already, I suggest you do a clean install with the latest beta.
Confirmed, can reproduce, working on it
This is fixed in 3.75b407209 or later
APK is available for download at Downloads | Kustom HQ
